GTA wheels, need advice before buying tires
anyone
would someone tell me if they worth to repair ?
weather or not we think repairs are needed, mount them and then decide for yourself.
those look fine... you don't need to fix them. You can polish them if you want, to make them look good.
I run 245/50R16 all around, and they rub. I would recomment 225 in front, and 245 in rear.
can i do 245/ 50 /16 all around with a spacer ?? would they still rub?
Do i need long wheel studs to install GTA wheel?
I am installing my GTA WHEELS, and i was wondering do i need loong wheel studs to make the fit or safe?
PLEASE HELP
Bawa,
I found that I needed to run a 3/8" spacer. The wheel mounting surface is fairly thick, so you might not be able to grab enough threads on your stock studs.
... this is the problem I had
I bought some ARP extended wheel studs, almost 3" long. Moroso sells them too.
The next problem I had was that these studs were TOO long and the normal acorn style lugnuts would bottom out before tightening the wheel. So instead of cutting the nuts, I ordered some 1" long open ended lugnuts, you can find them on Summit in the Gorilla brand. Make sure that you buy quality lugnuts with a deep conical seal. Otherwise, you won't be able put a socket on them, and you'll strip them.
The other thing you can do is try to find some studs that are only 2.5" long, instead of 3"........ I had a hard time here, so I just went with the long 3" ones... but you might have better luck.
Thank Khan, so i should do this on all 4 right? or just the rear ?
i am running 255/50 on all for corners. i got spacers on the rear. front rubs at full lock, other then that no issues at all.
