H-PIPE EXHAUST OR X-PIPE ??
judging by your set up i'd say you could get away with just straight pipes no crossover. it'll be louder especially with either the 40 or 44. the h or x should help dampen the noise and if youre hellbent on running either of them just run the h pipe, its cheaper and easier than an x pipe. anythings better than a stock exhaust at this point its just a matter of taste.
Both an H and an X balance exhaust pulses and give the exhaust another flow path(less restriction).
They will drop the exhaust sound a couple decibels and smooth it out.
They also will give a small hp/torque gain (5 to 10 hp/ 5 to 10 # tq @ the rear wheels).
The difference is the H becomes ineffective very low in the rpm range , gas/exhaust does not like to make 90 degree turns.
By contrast an X will provide these gains throughout the rpm range and tapers off right after peak rpm.
FYI , this info is from observed dyno testing (ie swapped out the h and installed an x).
Great reading - no Dyno test, but actual 1/4 mile and 60 ft comparison, which means more to me than actual HP
http://www.boyleworks.com/ta400/psp/exhaust.html
copied from one section of the article
Crossover Test Results:
By reviewing the data in figures 8-10 (below), it can be seen that when comparing the H and X types, the X crossover not only reduced 60 foot times and quarter mile times but increased trap speed as well. Functionally, the difference between the X and the H is, the X type forces the exhaust to cross between both sides. Based on the performance increases we noted with the X crossover, the scavenging forces created by the gasses crossing over in this way appear to be stronger and more effective across a wider range of engine speeds.
I have an "X" with cutouts. I was running headers out to some Thrush weldeds before the x. Sounded mean and clean. But after adding the X, I wont go back to straight pipe out to the mufflers. The X smoothed out the exhaust tone nicely..
Flipped the piping around so the exhaust would flow right out the opening when the cutout kit opens....
The H pipe does make the exhaust note a lil deeper sounding to me. Take a look at some vids on youtube. Be sure to note what kind of motor the car has and mods done. That plays a role in how the mufflers will sound also. I looked for Thrush welded on a SBC 350. Worked out sweet. I found a setup very simular to my motor and loved the sound clip. Mine sounds just like the vid upload. Hope this helps bruh..
Elco Warren 8)
Pat, I'm sorry, but I do not trust your information anymore, besides by dis-proved I meant significant gains that 84regalsbc23 said, sorry for the confusion as I re-read my post it doesn't make since, so let me re-type. As far as significant? No... are there gains? yes but for the cost of the pipe/labor/welding, to me at least it just isn't worth it for power you won't feel at all and if you do it's very minimal.. it's all in the sound you want to make!!!
And why do you not trust my information anymore SScamino? This goes to everyone on the forum who doesn't trust my advice. What I say and give advice on is from personal experience and years of research. I simply post what I know on the subject and leave it at that. It's up to you to interprate it the way you want.
But do us all a favor and keep your interpretations to yourself.
thanks for all the suggestion big big help thanks everyone ...!
