??Has Anyone Painted/Dyed their Console/Dash??
Fader
144
42
Eastern Nebraska
Just like the title says.... I've heard of but never seen....Products that you can use to turn a FADED center console into a New Factory colored console once again....I'm gonna do a little online research on it, but figured I would start here & get peoples opinions....Let me know what brand you used, difficulty, cost, time, & final results....thanks in Advance....
I've used SEM brand and Dupli-color's brand from the local auto store.
I like the dupli-color stuff the best.
Took my dash from a dark blue to black using it as well as a beige center console to black.
My original dash:
And after a few coats of Dupli-color black:
I always used Sem brand out of my touch up gone. Make sure the parts are clean. They also make a prep cleaner. Prep is every thing when you paint anything. Paint in as dust free environment as you can with lots of ventilation and use a respirator.If you do it right you will not be able to tell it was ever an other color.
Good luck
Thanks 4 all the responses...I've got a burgandy console that I need to spray grey... I also want to start looking for a dash & wanted to know if it has to be the color I needed... I think I'm gonna order some soon...
viewforum.php?f=16
Didn't even need the search option on this one :roll: It just gets annoying seeing the same threads over and over again ...
...what rear end will fit in my GBody?
...what backspacing do I need on this rim?
...what size tire can I run?
I think these duplicated threads need to be immediately deleted and the link to an existing thread be PM'd to the user :idea:
RITTER said:
http://gbodyforum.com/viewforum.php?f=16
A simple "plz use the search function k thx" would probably work just as well....
Here you go....I ues SEM paint for my center console...and looks sweet!!!! i love the finish and no fading what so ever,..
i actually did my hole interior black...
did my whole interior black with duplicolor carpet and vinyl dye. no fading or peeling after more than 7 months and most of those were sitting outside in the sun. i think i used just over a can to do my dash. pretty sure i put 4 coats on just to be safe. light coats work best to avoid runs and get a consistant finish. the stuff is pretty cheap. i even did my carpet with it an all my interior was puke green. remember PREP IS EVERYTHING
