head gaskets?
I just looked on SummitRacing.com for GM Vortec heads and then the suggested parts. Listed is a 1003 Felpro gasket which is the same gasket I used on my 383 with conventional style AFR heads. So, a vortec head uses the same head gasket as any other conventional head gasket. You can therefore use any sbc head gasket you want.
Vortec heads do however use differant intake gaskets and intake but I bet you already knew that.
