Can anybody identify these headers? Will i have clearance issues on the passenger side? It looks real tight in there with the starter and bellhousing..etc, i got them for free and the previous owner said they came off of an 86? monte?
Escaped_Psyco said:You'll want to run a mini starter anyway to avoid heat soak
pontiacgp said:Escaped_Psyco said:You'll want to run a mini starter anyway to avoid heat soak
x2......and a remote solenoid
crotchss said:If the headers are Hookers they say u can't run a 168 tooth flywheel, but I have done it by dimpling one tube a little. They should have a number stamped on the collector or head flange.
