Header Heat + Wires
3XBrownCutty
1,820
9
38
NW PA
www.cardomain.com
I am trying to figure out the wiring to the starter and such, and I'm pretty concerned about the heat the wires will be exposed to.
I'm looking around at Summits catalog and they give a heat resistance # of their wire protection materials.
And I got to wondering: How hot do headers actually get?? I think I should know that before I order the stuff.
Also, what gauge is the smaller wire that comes from the + (I think) battery terminal to the starter?
What you can do is install a Ford starter solenoid on the firewall, then run a cable from that down to the starter. Then on mine I have a guage 6 solid copper wire jumping the battery terminal to the I terminal on the starter solenoid. This way, the only time there is power on any wire going to the starter is during cranking. I also have an aluminum wire heat shield over that cable. I haven't driven the car yet because it is still being worked on to get it running, but I think this is a good set up, at least in my mind it is.
outsider_27 said:
What you can do is install a Ford starter solenoid on the firewall.
That is a great idea, I have seen that done on a lot of cars, I would have to say it is one of Ford's better ideas. I currently used heat resistant wire I picked up at NAPA. And I have heat sleaves over my plug wires, after you burn through a set of MSD wires you get smarter.
That is one thing ford got right. Also for your spark plug wires use moroso's "Blue" race wire set. They are almost impervious to heat. While breaking in a friends twin-turbo 502, we accidentally laid one of them right across the hot-side housing of the right turbo. The housing was glowing when we noticed it there. After moving it, we expected to find it melted, but it was fine! Not even dis-colored! They are very pricy, but you wont find a better set anywhere!
Good luck!
Good luck!
I use the Moroso Blue Max wires on my street car and we use them on our circle track car. Your right that the fiberglass covering does help to protect the wires from heat but if they are laid directly on a header the protective layer will burn and the wires will be damaged so I don't understand how the wire covering wasn't even discolored after laying on a a housing that was glowing. Before I installed the heat shield sleeves on the wires I fried 5 of them with headers just firing up the car for a few minutes to check the header installation so I can certainly say that laying them on a heated source will damage those wires
Ford solenoid is genius. I run it on my car.
We were shocked too! We were sure we had just ruined an expensive set of wires. It was on there for over a minute! Good stuff! Just bought a set of them for my 383 T/T build.
there are the type of wires I am using...
http://www.moroso.com/catalog/categoryd ... 4&pt=72405
if you care to read the covering over the wires is added insulation to protect the spark energy and has nothing to do with protecting it against heat...those who are suggesting that the wires are basically indestructible when coming in direct contact with a high heat source are incorrect and should be disregarded...
The Ford Sloenoid thing sounds like a good idea. Maybe something to look into down the road.
Not really concerned about the plug wires since the plugs are above the hearers (Go oldsmobile 8) )
Just looking for some kind of very heat-resistant sleeve.
