Header issues. (SOLVED)
Re: Header issues
chevy2480 said:
Mx372 said:
drop the z bar set up and out a hydraulic set up in there. clear any header then!
I would agree but not a fan of hydraulic I like the feel of the old stuff.
I have a hydraulic set up and use a Howe hydraulic throw out bearing. Makes it a simple set up and I didn't like how close the header was to the slave cylinder.
Re: Header issues
chevy2480 said:
Ok here goes i have been trying different headers and they dont fit. And no one seems to be 100% certain on which will fit. I have a 84 Cutlass sbc with angle plug heads and factory manual zbar setup. Seems to be a problem finding headers that work with both. Tried hedman shorties no go. Tried flowtech shorties they hit the frame. Now i think I will go long tube. Any help would be greatly apprieciated.
not really sure than i have hedmann headers but i dont think that will work with the zbar setup try this link it might help you out though viewtopic.php?f=14&t=2372
Re: Header issues
A lot of header manufactures say you have to run a cable shifter when using long tubes. i think on manuals you have to use shorties. idk if you can fit mid length or not
Re: Header issues
lilbowtie said:
Ok I quit - Sounds like you've got some nice machinery.
Lol. Seem to grow by the day. Just scored another Cutlass supreme today. Not sure what to do with that one. I should just sell them all and buy a new Dodge challenger with a Heminand put a pro charger on it and call it a day.
Re: Header issues
I have heard that the shorty style headers in the g body to small block chevy are a pain in the butt to work with I am going to run long tubes just because of that problem
Well finally got a set of hearders that fit with just a few minor dings needed for clearence. And yes they work perfect for angle plug heads and the factory manual zbar setup. I went with a set of Patriot H8047 appear to be very well made all flanges are nice and thick. So if you want to run a sbc with angle plugs heads and a zbar these will work for you.
