Fast flow is not so good. That is why not having a thermostat can overheat the engine. If the coolant passes through too fast, there is not enough time to release the heat. Even race cars use a restriction washer to slow the flow so it can be effective.
The duct temps went from 120° to 145°.
A car is not like an industrial cooling system. It is limited by design and function to what works best in varying situations. That is where it differs. Airflow is limited by the radiator, fan, grille, and outside airflow from the car's movement. The heater fan speed is limited to the blower motor and heater core design limits coolant flow. I agree that if coolant speed and airflow were constantly increased simultaneously then the cooling capacity would also increase. But they are not. The car's design limitations prevent that. I am reminded of a 1967 Firebird parts car that had a 400HO motor and a manual transmission. It had manual steering and the single fan belt ran the alternator and water pump. The pulley on the water pump was HUGE, the largest I had ever seen. What that did was slow down the flow so the radiator could handle the heat of the HO motor. I have used that same huge pulley to cure overheating in several of my Firebirds. But I also agree this is going nowhere. Later.in general, the faster the water and air flow through and around the radiator/heater core, the faster it cools the fluid.
