What year make an model should I look for when I get a mini gm starter for my olds 350
You will not find a mini starter on any newer GM make or model that will fit your Olds 350. Olds starters are on the driver’s side, while the corporate (Chevy) ones are all on the passenger side.
Not to mention the tooth count on the flex plates will likely be different. What the guys are discussing above only pertains to Chevrolet engines.
If you want a high torque mini starter for your Olds, there are several quality ones available in the aftermarket. Take a look at PowerMaster, Tilton and many others, Summit Racing is usually the best place to compare specs and prices of stuff that will fit your application.
