So does this mean you can drop the distributor flush to the engine and the rotor can be in any position but you will have to set your number one spark plug wire at that rotor position on the distributor cap ?
What is an even fire engine in what is an odd fire engine?True for an even fire engine, but you would have problems with an odd fire engine trying to make number one whatever tower you want. If you don't understand exactly what you are doing I would ignore such things, valid or not.
Yeah I understand the concept you take cylinder one spark plug wire and run it to whatever terminal that sits where the rotor was before you put the cap on and follow the firing order from there... It's as easy as routing the cylinder one spark plug wire and going in the fire order at the cap to figure out the order that it's in if I did it that way... But I didn't, instead I adjusted the timing and I believe I was too far advanced because my daughter response was delayed and my exhaust backfired when I was driving it today.. so I retarded it and now the response is much better and it doesn't backfire even when I floor it.True for an even fire engine, but you would have problems with an odd fire engine trying to make number one whatever tower you want. If you don't understand exactly what you are doing I would ignore such things, valid or not.
