HEI PICKUP COIL Not Reading Correct OHMS
jessedukhia
47
9
8
Today I re-tested everything on my HEI system on my 80 monte carlo. The pickup coil did not test correct. I put one lead in distributor body and the other on terminal on pickup coil it showed infinite, so that ok. Then I put both multi meter leads on pickup coil terminals it showed infinite again instead of 800-1500ohms. How can this be its a brand new distributor? Can I fix this without replacing pickup coil i.e. is there a ground wire I should be aware of? Because like Is aid its a brand new distributor.
P.S. there is bare wire near the pickup coil in the distributor housing coming from the ECM harness would that cause any issues?
Good informative video, Steve.
That pretty much sums it up in simple terms.
Thanks pontaic GP. I will make sure my connections are tight. I think thats all it is.
