Hello GBF! From Gettysburg, PA
Thanks for all of the warm welcomes!
As far as a low down on the combo, it goes as follows:
Gen3 5.3
*All stock bottom end down to the 120k OE bearings (pulled apart and cleaned everything up)
*Re-gapped rings .028 top/ .030 second ring
* stock 706 heads w/ PAC1218 springs
* Texas speed 224R cam .581/.581 224* on 114 LSA / LS7 lifter and trays
* Trick Flow double roller timing chain
* stock truck intake/ throttle body & fuel rails w/ 80lb siemen dekka injectors
* On3 76/65 turbo, 3" A2A ebay intercooler, 44mm gate
* ARP head studs and summit MLS head gaskets
* holley hp efi controlling everything w/ twin AEM 380s pushing fuel
*e85
* th400, reverse manual VB, custom billet converter from Greg @ R&R converters
*8.5 rear, Eliminators, mini spool and Richmond 3.42s
*8pt cage
*weighs in @3570 with my butt in it
Have no clue what the hp/tq numbers are. This past year the car went 11.40 @ 125 with a 1.86 60'....10psi and 14* timing in the tune (Wanted to stay conservative to get a base line )
Only got in 2 passes before a racer had a bad break and oiled 3/4 of the track late on a Friday TnT.
This year I'm building the trans and putting in a brake in hopes to get this thing to launch. Like to get into the 10s with it
