help , dropped rear on GN 3", no travel left
WOW....you are the man 442!
OK, I like the height it is at, it really isnt that low looking....so I wanna stay this height.
So you think my best option is a predropped spring 2"+ if anyone makes one, (this was suposed to be 1.975" drop from OEM...but actually raised my car) or second option is maybe a coil spring w/ a near oem rate so when a coil is removed it will make the rate closer to an aftermarket rate and be dropped down?!!
I like everyone am on a budget, and when my moogs installed were 1" higher than my OEM 1986 coils I couldnt have it.....the ziz wheel had to come out.
I am contemplating using my OEM sagged spring w/ a coil removed (softer rate than my moogs obv) and w/ the new shocks maybe I'll be near where I am now w/ control and a more reasonable rate.
Am I following you? I know cutting a pig tailed coil isnt a great solution, but 3" drop on a G body rear seems to be like shading the sun w/ a magnifying glass.
This is just stuff I've picked up from books and here on the forum.
I would try to find a drop spring for around a 2" or more. It could be hard to find, but it's worth getting a decent spring rate. And if you must cut a coil, yes make sure it's a softer one than you started this time with. I think most of these cars came with around 115 lb/in springs. You could also call moog and should be able to get the specs on a few different springs that came stock on your car. It's not really recommended to cut over 1 coil but people have done it
You can also google to find spring rate/wheel rate calculators that will help if you'd like to try another moog spring.
I'm wondering about this one, where did you get that info from?
TurboBuick.com had a big Moog thread where people w/ OEM cars measured before and after certain spring installs.
I found my issue tonight when I removed the coils and let the car down.....rear calipers barely hit frame still. I will have to notch teh frame up a few inches at that point to clear them.
Friggin rear disc conversion!
good to hear you found the problem! make sure to look into those upper a arms.
I need adjustable ones? I'll rer-read this thread, It was a lost to absorb.
Again, a BIG thx to you 442, I really appreciate your patience.
that was a mistype, you need upper adjustable control arms on the rear...
I guess now that I think about it, adjustable front a arms aren't a bad idea either... but stick with the adj. rear ones for now
give one of these guys a call and they'll help you with setting a correct angle. My guess is you'll only need upper arms, but they'll let you know
http://www.scandc.com/currectrac.htm
http://www.umiperformance.com/catalog/i ... cPath=8_60
