I'm stumped here. Having a frustrating morning, I need some help.
1986 Regal 307, Auto trans. Let me start from the beginning. I purchased this car 1 week ago. She had a constant "ticking" noise from her engine. It is not oil starvation/valves. I am still diagnosing it. That being said, she ran well enough. Driveable. Slowly that changed, accutally it was sporatic. For example, 5 days ago I started her and she well perfect. No stalling, no ticking. Drove around. On the return trip, when I started her- it was like mr. Hyde. Ticking, rough idle... but still driveable enough. 3 Days ago I performed tune up- changing coil, rotor, cap, wires, plugs, fuel filter, air filter, PCV valve & filter, oil & filter. I also changed out to a better new battery. I tested her after... and she ran the same... maybe a bit better. Still ticking, still trying to stal under load/in gear. At first she idled for 15 minuets, but after the drive I parked her, and in 2 mins the engine was out again. Worse, without working with the throttle while parking her, she stalls. I park her, and came back thius morning...
Same condition. Now I go to diagnose the situation, I started with the EGR valve. I pulled it off and checked for carbon, anything. It seems fine. Now heres the kicker... after reinstalling it and going over the cauume lines.... Mr. Hyde to the extreme. Fast idle in park, with surging, and stalling out in gear. I didn't change anything I'm sure. I went over about 60% of the vacuum hoses. Heres the biggest issue, the previous owner had "rebuilt" the engine- and missed the point of what reinstalling means... meaning he left quite a few connectors unpluged as well as reinstyalling the AIR pump, but not routing the hoses back up. I cant begin to diagnose the possible vacum leak, the hoses are prob mixed up, or there is a broken sensor. This guy reused everything. I have performed a compression test, the engine is good.
Guys, I just need some help here please. Im at my witts end... any ideas are greatly appreciated.
