Hey Everyone! I have a long list of upgrades to do this winter to my 1986 Olds Cutlass. My current setup is a vortec headed 355, Howards roller cam 180325-08, 10:1 compression, 2800 stall converter, Th350, ford8.8 rear end, Factory 14x6 olds Rally Wheels , and factory replacement monte carlo ss supsension through out.
For the winter I am planning on putting AC back into it, a 200-4r OD transmission, dual 2.5" exhaust, and hopefully new wheels, tires, and suspension so it doesn't handle like a complete mess...
Right now if your driving down the road and you jog the wheel back and forth there is a huge amount of body roll and it just feels horribly sloppy. It worries me that if the car ever got loose and started to get away from me there is no way for me to recover. I am not into road racing but I would like it to handle much better than it does now. What would you guys suggest?
A lot of people say to start with anti roll bars and wheels. I figured due to the factory 14" wheels I am loosing a lot through the large amount of side wall I have. I really like the design and look of the Olds rally wheels on my car but I believe the largest size the factory made were 15x7 which idk if that will give me enough of an upgrade to make it worth it. Can anyone suggest maybe a tire that will allow me to use the factory 15x7s or possibly an after market wheel that would retain the factory look but maybe let me run some more tire front and back? I am having lots of issues trying to get the tires to hold. You get on the gas at all and the back tires just break loose.
Also since I swapped in the 8.8 the axle tube is bigger in diameter so the rear end sits really high. I would like to drop it down some so I will have to look into some lowering springs probably front and back.
Also is the factory power steering setup worth upgrading? Leave it alone?
Sorry for the essay here but I just want to give you guys as much information as you will need to help me out as much as you can.
Thanks!
Shane
Thanks!
Shane
