I SET THE TIMING AND NOW WHEN I GO TO START IT IT SENDS SMOKE THROUGH THE INTAKE ALMOST EVERY START SERIOUSLY NEED ADVICE ON THIS ONE
i set it to 8 degrees like it says on the catalyst and stock distributor with msd cap and rotor and yes stock vacuum advancebjohn07 said:timing is prob off. what did u set it to. and what kinda dizzy do u have? stock vacuum advance?
when it was at 10 she ran a lil rough...do i have to adjust the carb or will that not affect it too muchPontiac455 said:set her at 10 deg and run the advance on a ported vac.
