CHRIS.O said:Why did you replace the gaskets in the first place? Did it blow a gasket or something? Just wondering if there are clues from before it was taken down.
CHRIS.O said:If your block is good then just buy your friends heads assuming they need no work and bolt it back together. Or now could be the time to upgrade to some vortecs Or re use the other heads if you want to have them milled.
