I just got done talking to a guy over at Lunati. I was asking for a comparison between their 60102 cam and Comp Cams recommended XE268H. He said they're very comparable and not much difference.
The main issue he raised was the fact that I'm running stock stamped steel rockers on my 350. The lunati has a .468/489 and the comp cam is .477/.480 lift. He said because these camshafts are running at and over .480 lift, the stock rockers will possibly bind on the rocker arm stud because of the lack of rocker travel. Can someone put in their two cents on this plz? Is this true or is anyone running a similar set up without any problems?
