HELP, what is this horn part called?
Fredo
13
Hi folks, last night I was fixing the sloppy tilt/steering on my 87 El Camino and I got a little ahead of myself on reassembly and managed to break the plastic internal horn contact ring.
My problem is I'm trying to order a new one but I cant seem to come up with the proper name or description. Please look at the pictures and let me know if you know what this is this called? Thank you in advance!
Fredo San Diego CA
69hurstolds
8,198
17,600
Makes a difference if it's tilt or not.
TILT
Uses GM part numbers 26004233, 7812051, 2609509, and finally 26047013. The numbers are in part number supersession order.
NON-TILT
BUT- if you don't have a tilt wheel, you need the non-tilt cancel cam. #7812136 superseded to #26029510 for the NON-tilt version.
  • Informative
Fredo
13
TILT
NON-TILT
It is a tilt, I was worried about you post for a second I had to dbl check the numbers because I ordered one as soon as I saw the first reply.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I noticed you have a tilt so the link I posted is for a tilt and has the same part number that 69hurstolds posted, it's the 3rd one in his list for the tilt column
