Help with Pivot Pin/Broken Bolt Removal ***Pictures added***
hammer drill is used for going into concrete. Doesn't work on steel ( you'll just kill the drill bit )
He means a impact drill, not hammer drill. They do work well.
I'm actually pretty sure its a hammer drill. I've heard that it is best used on concrete but the cobalt drill bits have been strong enough to hold up against the vibrations.
I've done a lot of drilling today and now the plan is to tap the hole (re-thread) and use a larger bolt for a puller. The only problem with this is that the taps that I'm using are all tapered at the edges so I lose about 1/4'' of threads. The threads have not been deep enough to hold any pullers in place. I've even tried torching the puller while it was screwed in so that it would expand and maybe hold better but no luck so far.
Are you sure it's a hammer drill? those things are about 4 feet long and have a drill bit about 1 inch thick. It is way too big for your application, i have a impact drill which looks like a regular cordless drill but it "hammers" at the same time it turns. That would be perfect for what you need.
Oh sorry. I guess it is an impact drill. I've always heard of them as hammer drills.
This is all getting very frustrating now. The tapping process isn't working very well. I'm getting very desperate now. Considering that this tilt assembly is used is so many different cars, I actually wouldn't mind breaking that one pin and getting a new one from a scrap yard. Other than doing that, this is my next plan of action:
I know that it seems that with a hole that long, the pivot pin is structurally weakened. My solution to this, since I'm so good at it, is to break a screw off inside of the pin and leave it there. Maybe some 40 years down the road someone will try pulling it off and have as good of a time with it as me hahaha.
