I bought this 3.73/posi/7.5 differential and it came with an unfinished rear disk brake setup. Looks like a fourth-gen disk drake (LT-1), but I'm not 100% sure yet.
As you can see, the caliper bracket (with the two red bolts) is located in front of the wheel.
I have read about clearance issues with the chassis with this setup. Any more details on that?
Also - the bracket itself is made of a 1/4" plain steel plate that was welded to the differential. Would this be sturdy enough in your opinion?
