A couple of weeks back I replaced the steering box with a LARES F41 box.
When I replaced the box I also replaced the pump and both lines.
Started it up ran it turned wheel lock to lock a couple of times.
All was good, back in garage
Haven't drove it been focusing on the Monte.
So now I think the Malibu is jealous................![Doh :doh: :doh:](https://cdn-0.gbodyforum.com/oldsmilies/doh.gif)
Went to take the Malibu to the local cruise spot last night.
Pulled it out of the garage no problem.
Washed it and got into it to "air dry" it zooming down the block.
Well half way down the block I notice the steering is tight.
It feels nice and tight.
I say, hey it must be the new LARES F41 box I put in.
Make a turn it's tight, make another turn it's tighter.
Come to a stop sign it;s so tight you can barely turn the wheel.
Rev it up and you can turn the wheel.
Pull it back into the yard and two hand to turn the wheel while it is at a stop.
So this morning I get under the hood crack the pressure line fluid is shooting out.
Crack the return line fluid is shooting out.
So I am guessing the "new" rebuilt pump is working.
Drop the steering box out put my old one back in.
100 times better but the pump is making noise.
So is it the pump not pumping hard enough or is it the LARES box????????
Did the F41 boxes use a different higher pressure pump?? I don't think so.......
I never had this many problems before with parts
Are these rebuilders just retarded?!?!?!?!?!?
At this point I think I am going to just install a manual box.![BLAM :blam: :blam:](https://cdn-0.gbodyforum.com/oldsmilies/BLAM.gif)
