Hestitation with stall! Holley
Have you adjusted your accelerator pumps? Should have a slight amount of resistance checking the pump arms with a .015 feeler gauge. You should have no gap between the arm and the spring base.
Do you have the 64 or 72 cc heads?
Your not doing bad for what you have got - since your drag only and getting a weak signal to the carb are you running a power valve?
