when installing intake gaskets, do you put high temp rtv on bothe the heads and the intake or just the intake?
jrm81bu said:Aren't you using a Vortec style intake?
jrm81bu said:Then the right gaskets should be plastic with rubber seals. No rtv needed. Looks like Edelbrock has a paper style gasket for them which i'm guessing is what you have now. If so the you could use some rtv with them. But that is why you had sealing issued before, you had the non vortec style gaskets.
