Hood Hinges
realjwann
14
Do the hood hinges change from steel hood to aluminum hoods?
Yes, the spring part does. If you have the aluminum hood, you will need to get the hinge springs as well, but they are a separate bolt on part of the hinge. They have lower tension so that you do not bend the hood when you shut it.
I was thinking about maybe just heating up the spring with a torch to unwind the spring rate, i have looked on ebay and car-part.com and no luck finding the correct hinges for the aluminum hood...
I tend to think that will not work. It may just make a big mess. If you like to fabricate things, you could try the gas struts from a 1982-84 Z-28 with the factory fiberglass hood. They have lower pressure than the struts for a steel hood, and may provide a solution.
