Horn fuse
have you tested the horns so you know they work?. If a relay is burnt then there would be no noise from the horns by grounding the wire
on the 1978 Regal/Century the relay is located to the left of the radio in front of the ac vacuum valve.. I will upload pictures later.
Here are photos as promised
First one is looking at it from where the radio sits. Took radio out for photo. Second is from looking from under steering wheel towards passenger side. Third is actual location of relay.
Reactions: BuickBroke$
