Well, I am curious as to what the symptoms are for a worn out TPS sensor. My 98 Nissan Frontier ( 2.4 Liter SEFI L4) has it's original sensor at 280,000 miles. The thing is, the truck now idles great after fixing a problem with a bad injector and plugged EGR passages. It throws no codes and seems to have a pretty linear acceleration curve. However, it does feel like it is surging a little under acceleration and it can buck a bit under low speed driving (5-10mph, like in a parking lot). It just feels like it is being held back, kinda like a carb with too small jetting. Fuel pressure is good with 36-45 PSI, varying within spec according to the FSM. I have also seen my city fuel economy drop from 23-24 mpg to 20-21 mpg. The tire pressure is 45 psi all around and checked weekly, so I know that's not it. I am replacing the fuel filter tomorrow since it is about 30k miles old. This is a VERY anal-retentively maintained truck, so I doubt it is a normal tune up item that is bad (It gets looked over every week and anything it needs gets done almost immediately). Heck, the engine is so clean inside that you can't easily read the dipstick after an oil change, or for 500 miles after that! ( I flush it with cheap oil every 2 changes and do a double change)
