it got bent when I pulled off the manifold and the gasket stuck to the manifold, so when I pushed it back into place, it just snapped off flush... so, I tried pulling it out with a coat hanger made into a "J" hook, which I just knew would work....and it didnt budge....lol. I also tried an easy out, but that just started chewing it up. Im so pissed that I didnt put a new one in when I had the motor out of the car. Thanks for the ideas....I guess the pan will just have to come down....tk76 said:First spray with PB blaster no mater what. Did it brake or rust off? Also is it flush with the block? If its not flush you can use small vise grips and wiggle it out. Take your time don't rush it and watch to make sure the whole tube is moving. If it's flush you may need to take the pan off.
you could take a punch and push one side of the tube inwards some and use a pair of needle nose to pull it out, just another suggestion before the pan drop....bill said:it got bent when I pulled off the manifold and the gasket stuck to the manifold, so when I pushed it back into place, it just snapped off flush... so, I tried pulling it out with a coat hanger made into a "J" hook, which I just knew would work....and it didnt budge....lol. I also tried an easy out, but that just started chewing it up. Im so pissed that I didnt put a new one in when I had the motor out of the car. Thanks for the ideas....I guess the pan will just have to come down....tk76 said:First spray with PB blaster no mater what. Did it brake or rust off? Also is it flush with the block? If its not flush you can use small vise grips and wiggle it out. Take your time don't rush it and watch to make sure the whole tube is moving. If it's flush you may need to take the pan off.
tried that....couldnt get enough bite on it. thanks though...my86442 said:you could take a punch and push one side of the tube inwards some and use a pair of needle nose to pull it out, just another suggestion before the pan drop....
