TexasT said:
What makes swapping in a Buick 350 illegal?
What makes you think that a 3.8L is "stuck" at 110hp?
I would be more willing to state that your 305 is limited with the small bore and poor flowing cylinder heads.
I will agree that the 200-4r is a better unit than a thm-200 but what makes you think that it is better than a thm-350?
While it does have an over drive in its stock configuration the thm-350 will take more abuse. Either of those three can be upgraded into a very hd unit but you better step up with your bigboy check book, as parts and a good builder ain't cheap.
There are some pretty stout Buick v-6 Busch series engines floating around that post some pretty hefty numbers.
Because Buick 350s are older than 80s Regals, it is always illegal to swap an older engine into your car. They also lack a computer system which makes them illegal in a computer era car. A computer controlled car must always be computer controlled to stay street legal. Of course if you are building a track only car then you are exempt from the law.
Since THM 200-4R has overdrive they save gas and reduce wear and tear on the engine while being able to use better rear axle gearing. You can have your cake and eat it too with an OD trans.
L69 heads are better flowing than any 80s factory Buick V6 head, even the GNs, (but they had a turbo to more than make up for it). The small bore only become a limit well above the street driving RPM range. For a full on race motor it would be a problem, but not for a street engine mated to an OD trans. There are quite a few beefed up 305s out there putting out hefty numbers too, they are very underrated engines.
N/A 3.8s have poorer flowing heads than 305s, crappy 8.5 CR, are a 90 deg V6 (really should be a 60 deg), peanut cam, lack of aftermarket support, etc. I tried the 4 bbl swap using a factory 4.1 intake and a Buick E4ME Qjet, only gained 5 HP. The N/As biggest drawback is the low CR which causes it not to respond well to mods. L69 305 have 9.5 CRs which makes them respond much better. The only way to hop up a N/A 3.8 is to either to completely rebuild it to better specs than stock or convert it to a turbo setup.
At any rate, turning any N/A V6 Regal into a performer is a 3 step processes, you need a better engine, trans, and rear axle ratio.
