It's easy to remove and replace, but you will need to get another lock cylinder for it if you do not get the keys with it. There is only one bolt that holds it to the splines on the steering box. You will need to rotate the gray plastic piece off the hose and pull it back to see the bolt. Just be sure you replace the steering coupler when you are in there because they are almost always shot. If you do not need to do it, you can also disconnect the column from the U joint in the shaft within 10 inches of the firewall. Again, it's only one bolt but this one has a nut on the other end. You will also need to disconnect the shift linkage by removing a single clip and slipping the shaft out through the hole.
