There is only one seal. Have you ever done this job? Do you know about pre-load? In case you don't and for the benefit of others- here ya go. The bearings are pre-loaded to a certain spec to keep them in position under the strain of drivetrain torque. You must not change the pre-load. The best way is to remove the drive shaft and wheels and then take a torque wrench and measure the pinion nut for pre-load and return it to that same exact spec. Or, second best, which we all do, is this- Begin by taking a cold chisel and marking the pinion nut and the end of the pinion gear shaft. Make it so you can return the nut back to that exact position. Then count the visible threads and WRITE IT DOWN. Now you can remove the pinion nut, washer, companion flange, and oil seal. Change the seal. Use a good sealer around the rim. When you install the companion flange smear oil on the lips of the seal and the flange surface. Also use a good sealer on the splines and under the washer or else oil will migrate down the splines. When you screw the nut back down feel as the slack is taken out and come up on the pre-load slowly. Return the nut to the EXACT same position with the same number of visible threads and the mark you made. If you under or over tighten the nut you will change the pre-load and cause expensive problems with the gears. Done. If you are really clever you will use a torque wrench and measure the pre-load first, do the above, and check it again when you are done. While you are down there, check the rear end oil level.
