ring and pinion paint check
ok i moved the pinion .002 closer to the ring gear and i have .010 backlash these are the new paint marks how does it look gents i rotated it by the carrier not the pinion
silly question how do you press the outer pinion bearing on .the inner i can do on a press but not the outer I have been using set up bearings . do the above pictures look right or does the pinion need to get closer to the ring gear?
Reactions: Sweet_Johnny
I have no knowledge on rebuilding diffs but I know others here have gone through what you're doing. It may take quite a while but the info is bound to be here somewhere.
yea opening up rears is like black magic not to many people know how .i have read alot online and by reading fellow members posts thanks all
