I can pick up a wagon with the OD (assuming 200R4, but I'll check the pan configuration) w/under 100k mi for around $400. Supposedly it's a great runner, but the body & interior are beat. Another car is needed like another hole in the head right now, but the addiction must be fed! Actually, I'd just scavenge the good stuff & take the rest in for scrap. Besides, parts collecting is fun. I haven't seen the car yet, just talked to them on the phone. Want to make sure this is worth my while before I drive up to look.
My guess is this is a 307/TH200R4 w/carburetor. Seller confirmed it's an auto w/OD, but didn't know much else.
For the trans, these are all dual pattern bellhousings, right?
What electronics & linkages will I need to take from the car before scrapping to make the OD & lockup work properly? I'll keep the driveshaft for the front yoke too.
For the front spindles, the wagons have the big spindles w/big rotors. How transferrable are these to G-bodies?
I assume the rear is an 8.5", but it won't share much in components w/the G-body rear ends. If by some miracle it has a posi, would that transfer over to my 8.5" G-body rear?
Anything else I should be interested in on this car?
Thanks in advance.
Thanks in advance.
