you should have a lightr geen wire coming from the heater control harness along with 2 vacuum lines and some wiring for the fan. That should have 12vdc on it when AC i selected on the controls. That wire needs to go to low pressure switch, then off the other side of the switch (usually 2 wires dark green) to ac compressor and high idle sol (I use one to signal electric fan relay). AC compressor should ground and head or intake on a black wire. sounds like its still got some ECM connections left over
