how to choose a torque converter
87chevyboy
288
2
16
34
Phoenix, Arizona
so im thinking my TC is out it.. i dont think its the right one for my set up it sounds like is grinding and doest take off like it should especialy with the posi rear end.. so im thinking of geting a newe TC but dont know how to go about buying one i need it for my set up now and the setup i will have in a couple months right now i have a 305 700r-4 with 373 gears and in the future will just swap out the 305 for a mild 350 and suggestions on what to buy that works well with out breaking the bank???
there are alot of factors you need to consider with a torue converter. power, rpm power band useage... etc...
If your going with a mild 350 you should be able to use a 2400 - 2600 stall. B&M makes one for about $160 for a TH350. should be around the same for a 700r4
its good and holds up. ive been using it for about 2 years now. but also see what the cam recommends. thats where alot of it has to do with
im thinking of going with one of the edelbrock cams the mild one with the lifter change
For your needs, I'd just get a factory D5 converter. There's always someone who has one and is willing to part with it for cheap. They'd stall somewhere between 2200-2300 or so, which is all you really need on a driver. When you start getting into higher stalls ( about 2500+ ), you really are much better off with a high quality unit. They cost more of course but are noticaebly better than the el cheapos like B&M and TCI.
