Re:
Thanks from me too
Mr. 81 said:Wow, thanks for all the info! I'll let you know how it goes when I get around to working on it this week.Bonnewagon said:Yes, find a port with full manifold vacuum, which will be around 20" at idle. Turning the screws in will lean it out which will raise the vacuum slightly, then it will drop and stumble. Turning them out richens it. You want to first richen it up, then slowly turn them in alternately to get the highest vacuum before it stumbles. So say you can get a smooth idle at 21", but leaning it anymore makes it stumble, leave it at 21". If you cannot get a smooth idle by this method, you have internal carb problems. A leaky float will cause flooding that no amount of adjusting can fix, it needs replacing. Also first check all hoses for vacuum leaks, another reason why you can't get a smooth idle. If this is a computer carb, it is supposed to self-adjust. But it will still respond to manual mixture screw adjustment within reason.
Thanks from me too
