Maybe it's just me but that comparison makes no sense. If they saw blowby once, but none on the other launches, then that was their screw up.
If you look at the pics FE3X put up after he painted everything and had all the suspension components in, you can see the added bracing that was placed in the key locations. Essentially he "kinda sorta" followed the same concept of why drag racers put cages in their cars. His design with the added bracing and aftermarket suspension components will prevent any horizontal or vertical movement of the frame.
No, I'm not saying that notching the frame is the optimum way of putting larger wheels in the back. In my case the paint and mostly everything is done and I just replaced the body mounts (which were a bit of a b****). The body isn't coming off and I'm not about to spend more time modding this car than I have to. No it's not half a**ing it, as far as I can tell, there are alot of people who have done this on GBF, Monte SS,
MalibuRacing, Turbobuick, and all the other forums, and have yet to hear of a single incident of structural failure.
If anything, this allows the rear end to "collapse" in the event of a rear end collision. IE the car will absorb the energy better.
