Yeah ditch the KYB excel G's for handling. I had KYB gas-adjust which were fine for an entry level shock that is comfortable (I wouldn't buy any shock lower than a gas-adjust) but they are on a different level than bilsteins and again a different planet than adjustable Viking or others. I convinced myself the $100 for KYB gas adjust was justifiable over the $75 for excel-G but the $200 for bilsteins wasn't. Instead I spent $800 on viking DA's for all 4 corners.
Ditto on checking bushings. If they are OEM they are toast. Can't have stuff moving around unexpectedly.
The stock upper arms are tough to get caster in with tall upper ball joints. As the spindle gets taller the upper ball joint moves up & out and pushes the tire out so to get good camber at static ride height you have to shim the UCA in a lot. I had the rear bolt with max shim and front at like 3/4 to get camber in and caster was so-so.
I bought these MCAR arms (he is on the forum here) as they allowed me to pull the camber in, run a 1" taller upper balljoint that is rebuildable, and put caster in. The aftermarket UCA from UMI or whatever which is a great option requires you to run both their upper and lower arms because it relocates the front front LCA point forward 3/4" or whatever AND pulls the UCA point back so it keeps the wheelbase the same. These arms are the 'cheap' way and shorten the wheelbase a bit but save you the $1200 or whatever over full aftermarket arms that I can't justify.
Only issue with this is you are limited to how much caster you run as the tire rubs the fender at full lock if you put in a ton of caster. The camber gain on turns is more than enough with this setup so I just set the caster as much back as I can before the tire starts rubbing hard and it's fine. The tire isn't 100% centered in the wheel well visually but it doesn't bother me.
I don't like pimping out my 'tube channel on here but I did this video a year or so ago. It's essentially a video ripoff of Chris B's 2+2 setup that he spoke highly of on the forum for years here before he jumped ship.
www.motortrend.com
This 1986 Grand Prix 2+2 Can Conquer Modern Muscle at 160+ MPH
Chris Bischof's 1986 Grand Prix 2+2 may get overlooked by most Pontiac enthusiasts, but he saw it's potential and transformed it into the ultimate racer!
