this was my 1st time trying out crazy glue to put all the pieces back together. anyhow crazy glue worked well on models and things like that so i gave it a shot this time around.
as you can see the back of the console had the most damage. i taped the back side, heres the front shot
i layered the front side with tape for extra support while the backside was drying out. after the glue was dry to the touch i then applied a thick layer of 2part epoxy to the backside and let it sit over night.
the next day it was like morning wood
hard as a rock.
after that i installed in back onto the rear of the console and applied 2 part over the cracks
to fill any gaps that didn't get filled by glue.
now the fun part
sanding. so far so good, the rear of the console is connected now its just 1 large piece like factory
i tired to get a couple of angles so you can see how smooth it is.
i picked up some bondo filler....i never used this stuff so i'll see how well it works out. the console is almost ready for paint. the next layer will be bondo and sanding again to make sure all holes are filled. if it looks good this step....im done, if its bad i'll sand more.
Im not into body work and things like that, i lean towards the mechanical side of things. im sure there is a better way but for me this seem to work fine and was pretty easy to do so im just passing on my tips. the 1 thing i know for sure is, there's a few different ways to repair this type of stuff but this method made the areas i fixed 5 times strong than any factory area on the console so im quite sure it will never crack again. I'll get the rest of the pics up next week because the next few days im slammed with person matters so the car stuff has to wait a couple days
