bill said:8.5" rears in the Gbodys were all posi units. Its possible that the posi unit you have may be worn out or its a 7.5" unit which may have been swapped out earlier. Does the rear end cover have a tag on it? If it says "use limited slip fluid only" on it, then its a posi unit. Check the sticker under the trunk lid for build codes which will tell ya what it came w/from the factory.
Anubis said:Air shocks had nothing to do with the G80 option. All Vin 9 G body cutlass' I have seen have factory air shocks.
