Chris Van said:I purchased a bolt in 9" from quick performance in the past as well. They will sell you the axles you need. If I remember correctly you can choose from a couple different brands that they sell. I personally went with Moser because they pay contigency money at certain races. However, if that's not an issue, I'm sure that the other names would be fine for every day use. You won't be dissapointed with Quick Performance. And like others have stated, there will be a noticable difference in the length of each axle.
So did u have to do any modifications to the drive shaft, or did it bolt right up to the Ford center section. And can i still use my stock drum brakes
