Just as it says. Will running the PS box with only two mounting bolts break the others? I know the PS exerts tremendous force. I don't have time right now to remove (break?) the others and fix it right now.
Thanks, but I have plenty.I have some good used original bolts if you need some
Time. As in I have none. I am battling to get my little fishing boat in the water. I got Bluefish from shore already and I want to go chasing them! I had water in the lower unit at the end of last season. I took it to my dealer guy in Feb. and after two months they gave up. A bearing/seal housing right under the water pump was corroded solid. It took me 7 hours to drill/chisel/drill it out. Now I can't get the exhaust housing seal assembly out either. So this motor is down for the season. I had to remove it and mount my other motor just to get it ready for the water. Then I added a front mounted hitch to my tow vehicle. Getting parts has been a problem during the pandemic. So my wagon sits around a lot but I do use it for big parts chasing and Home Dupa runs. I just can't spend the time to remove and replace it. I probably have 6 or 7 good boxes laying around from various GM cars. I will need to search for a non-leaky one and just swap that in. Then, my wagon is an '83 which used the newer "O" ring hoses. The motor is a '79 so I kept the '79 PS pump and a '79 Firebird PS box for compatibility's sake but it used the old style hoses. I would want an old style box to replace this one and it is going to be a big job I can't dedicate time to right now. I'll just park it until I get my life squared away.I have to ask, what the issue with removing them?
