I only mentioned the big tires because it's a contributing factor. The same thing applies to 4X4 guys. The larger the diameter, the less effective torque your engine can put to the ground. You need lower gears to compensate.lildudefl said:Most of these guys are against big wheels so some of the recomendations jump straight to the converter may be biased... most of the tired smog dressed 305s can burn rubber with deuces...I witnesed many...lol
dogshit said:.
DoubleV's post is very informative. You should try and apply that as well and you will like your ride better and better.
