There is somthing wrong with my motor. if it isnt started everyday it shakes really bad. then after it warms up the shake come out of it but it has a loud tapping noise as its the lifter. the noise increases and gets louder as you rev the engine so think it may be that. but i was also told that same nise could from the motor not gitting oil pressure, or the crankshaft could make that noise( dont think its this because the noise is at the top of the motor), a plug wire could be in the wrong spot, and or a head gasket could be cracked.
Whats your opinions and what would has to be done to fix it as well as cost
307 olds... this all happend after i changed the oil, ive cleaned all the sludge out
my gauges dont work so hopefuly as soon as it gets nice out im going to go through the gauges to see if i can rule out the oil pump, also im going to check the plug wires again
