I don't know what it is but I hate when people say a timing chain jumps time. I have never seen this. I have seen a timing chain slapping the side of the timing cover but still was not enough slack to "jump tooth". I have built a sh*t ton of engines and.never seen this. The only way I've seen that is with the POS nylon crank gear but that thing shreds and messes everything up.WyoKid said:im sorry, im having trouble keeping up with the car too. i have come to the conclusion that the car is a bi-polar woman during P.M.S. The car didnt want to start originaly after we fixed the firing order, so we thought that the timeing chain stretched and jumped time. the Next day went to push the car out of the way and said "what the hell" and gave the car an attempt to start.... it did so without a hitch.
it started and and everything is back to where i begain at the first of this post except the oil pump is good and there is now problem with the oil pressure. Firing order is also in check now
here is what is wrong with it right now --- motor shakes violently only when it starts, then smooths out completely
--- still has a light taping noise as if its a lifter.
--- oil smells absolutely horrible like tarnished. gas
The Quadra-Jet, in the opinion of many, is the finest carburator every made.WyoKid said:it has the stock quadra-jet(quadra-junk) in it. the car is usualy hard to start, and there seems to always be excess gas all over the carb.
could be a bad gasket or stuck float.these carb get a bad rap but when working properly and adjusted correctly ,they get better mpg and throttle response than any other carb i have used.my 84 monte has a ccc quadrajet on it and if iam driving it regularly it starts instantly ,just as fast as my fuel injected daily driver.WyoKid said:it has the stock quadra-jet(quadra-junk) in it. the car is usualy hard to start, and there seems to always be excess gas all over the carb.
