I need help identifying a problem.
xminnis
May 19, 2008
90
Kansas City, Missouri
When i cut the wheel all the way to the right and go in reverse i hear a popping noise it only pops once or twice. I cant tell if it is coming from underneath or over by the front left wheel but it is coming from one or both of those spots. It doesnt do it when i turn the wheel to the left and go in reverse and it doesnt do it anytime that i am moving forward. So only when i have the wheel turned to the right and go in reverse.
What could this be?
megaladon6
4,006
15
Danbury, CT
since it only does it in a turn to one side i'd suspect suspension.
first thing i'd do is jack up and support the front end so that both wheels are off the ground. then shake down the front end. you especially want to put a pipe under the tire and lever upwards to check the balljoints. you may need to get a good pry-bar and see if there's any play in the control arms--front and back.
Lawfree
49
It sounds like the same thing that is happening to my 80' Cutlass. Have not noticed if it's reverse or fwd. but it's a definite loud "pop' in the FRT. left. Sounds almost like the spring is binding up. I plan and rebuilding the FRT. suspension soon so if I figure anything out, I'll be sure to post it here.
midwestls
1,497
13
Bismarck North Dakota
my Monte use to do the same thing. Did some front suspension rebuilding (tie rods, ball joints ect.) and it went away. I'd say definatly check out the front suspension. If it ain't there maybe a u joint or bushing somewhere? :? Good luck
Blake442
6,865
2,002
Minneapolis
Check your control arm bushings...uppers especially...
My wagon does the same thing, and the upper bushings are GONE! I can't believe I drive that thing 100 miles a day.
The '81 Monte I used to have did it as well, same problem.
Next thing I would check would be lower ball joints.
