Hi had this same problem and after being told to test gauges, sensors, replacing the alternator 2 times,and talked to every mechanic I know and looking at all the post and wiring diagrams I found the the Monte Carlos that came with gauges have a wire with a 10 OMH resistor in it that you need for the gauges to work right. The Monte Carlos with idiot lights has a brown wire coming back from the alternator that fed through all the sensors / sending units back to the lights witch we do need now. So the answer is a 10 OHM resistor. I used a 10 watt 10 ohm NTE resistor and put it inline to the pink/black wire that feeds power to the gauges and it works great.
