Hi im new to this forum. i have a 85 buick regal. When i got the car the previous owner had put a motor from a monte carlo. Seems like they didnt want to wire everything in so they cut a lot of wires. That motor blew. So i picked up a motor from a cutlass. Had the harness on it so i rewired my car. Its been a journey getting it going. I had to hook up all the vac lines being as it had none. . i went to a couple of junk yards and found a regal with same setup. so i took pictures and ran my vac lines just like it had. I installed a new rebuilt carb and plugs. I am new to carbs. So im learning as i go. Ok so my problem at idle its a little ruff and seems maybe like its misfiring. i went to the shop were i purchased my carb and he unpluged a sensor on the carb and put another and said it wasnt moving fast enough and my ecm(computer) is bad. Is he right or just bs'ing me. While driving it runs ok. stumbles a bit sometimes but if i give it gas car runs decent. Thanks in advance for any advice and help. Also i set the timing at 8* according to emmisions sticker and when i come to a stop i get the oil/choke light but i give it gas as i start to go and it goes away.
