I found this while searching google, pretty good info. Also, the NAPA TP45 module is supposedly a direct replacement for the 990 modules with the same specs.
This comes from:
http://forums.performanceyears.com/foru ... p?t=408761
(Posted by fiedlerh)
I dug out my GM/Delco HEI book (publication SD-105) and found the following information. This is just a short summary pertaining to the polarity questions. I have more info which I will post later.
"There are three different ignition coils and three different pickup coils."
"Two of the pickup coils have opposite magnetic polarity and are to be used with the ignition coils of the same magnetic polarity."
"Opposite magnetic polarity pickup coils are needed because of the underhood relationship of the distributor location to the starter and battery cable. During starting, magnetic fields are created. The pickup coil can be affected by these magnetic fields and give false turn-on and fire signals to the module causing engine misfire. By using a pickup coil of proper magnetic polarity, the external magnetic fields will not affect the pickup coil in such a way as to give false turn-on or fire signal to the module."
"The third pickup coil has the same polarity as one of the other coils, but it has longer leads which are necessary in its application. Pickup coils can either be identified by the color of the plastic tie around the leads or by the color of the plastic connector at the end of the leads."
Blue Tie or black connector Body
1876210 (V-8) Olds (except Toronado), Buick
1891209 (V-6)
1880020 (L-4)
Yellow Tie or Yellow Connector Body
1875981 (V-8) Chevrolet, Cadillac, Olds Toronado
1880040 (L-6)
1892175 (L-4)
Clear Tie or Clear Connector Body
1876495 (V-8) Pontiac
Yellow connector
1894237 (V-6 200 CID)
Black Connector
1893894 (V-6 Even Fire 196 and 231 CID)
COIL IDENTIFICATION
"There are two types of coils that are integral with the distributors. They can be identified by the different color tach leads and the part number stamped on the coil.
The coil with the yellow tach lead (#1875894) is used on all Cadillac (except Seville), Chevrolet and Oldsmobile Toronado engines.
The coil with the white tach lead (#1876209) is used on all Buick, Oldsmobile (except Toronado), Pontiac and Cadillac Seville V-8 engines and all V-6 engines.
These two coils are very similar in appearance, perform identically, can be installed in any integral coil distributor, but are of opposite magnetic polarity. This was done to match the high tension coil to the magnetic pickup coil. The misapplication of these coils can cause hard or no starting and/or backfiring while cranking."
