Ignition problems please help
Jawan912
n00b
Aug 9, 2020
2
Just brought my 85 ss, went to turn key, and it turned rather then usual. No lights, no power or crank when I turn the key. So one said change the ignition cylinder lock which I did and still nothing. The some said the actuators rod may went bad. Im not sure what’s wrong. Should I buy new steering column. Which is pretty expensive
Jawan912
n00b
Aug 9, 2020
2
The key just turns freely it has no kick back like when you turn it on and it kicks key back it’s not doing anything like that
tellboy
17
newzealand
sounds familiar, had same problem, ignition switch has moved on its mounts- on the steering column under dash
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
lower the column and check the rod at the ignition switch to see if it moves when you turn the key
